ohh know.. .not this againPete_m said:LED nips?
ChoÞÞer said:any up dates??![]()
The cables that go from the the spine sockets on the inside, were too big. It was impossible to fit the motherboard on the tray wit hte wires fitted. The main problem was the VGA cable, as it was so thick and stiff. In the end ive managed to fix the problem however, by stripping the connector right down as much as I can. Its still a very tight fit, but at least it does fit. Remains to be seen however if the cables still work, lol. Anyway, here are some pics of the full fit. Sorry about the image quality.
Tony Soprano said:Looking good with everything plugged in, have you tested it by turning it on or do you still have to do some more things to get it working?
btw, it was a long two days![]()
Pete_m said:still looking good..
how far are you through the project so far?
Cant wait for the finished model!
tbz_ck said:Its really coming on. Nice work Khan m8.
i don't know whether its relevant now, but have you considered break out boxes or extension leads for the major connectors so that they can be plugged/unplugged from the outside without having to open her up?
It may help with wiring issues![]()
messiah khan said:They all are. Thats what the connectors down her spine are. The cables are simply to connect the spine sockets to the mobo.
