messiah khan said:You asking why it took so long or why do it in the first place? The reason it took so long is because the Aluminium is thick and takes quite a lot of work with the jigsaw to cut it. Also the drill battery was running down, so it kept jamming. Most of the time though was spent filing and sanding it down to a nice brushed finish. The reason why I have cut it out in the first place is two fold; First is to make it look better. The square motherbaord tray just didn't look right IMO, it didn't look mechanical enough. I know it probably won't be seen once im finished, but I want every part to be perfect, because it will annoy me if its not. The second reason for cutting it out was to give a slightly bigger clearance behind the motherboard for the cables in the spine. Unfortunately they stick out too far, making it very hard to fit the motherboardtray in place.
ok, question answered.
keep it up man, when someone goes to that much effort for something they're not going to see, and not have much benifit from doing, yet still spends 7 hours+ on it has my vote for prime minister
only kidding.. can't wait to see the complete item though
