Project Bloodfang - Case Labs Black and Red Build
So a problem occured yesterday in my planning I never thought about the speed controller on the pumps... put simply there was so easy way to access them. So a fix was needed.
First using a tool fassioned from a pair of tweasers, filed down and bent into a very tight 90 degrees, stuck my phone with front camera underneith to see what I was doing and turned the pumps upto max speed:
Now that was done I could then re-wire the molex and RPM signal wire into a single standard 3 pin fan cable which would allow me to control the pump speed via the lamptron touch controller!
Lovely, well worth the effort you've put in.
What tubes are you using and types of fitting? Probably going to use tubes instead of hose in my next build.
Bitspower fittings, the tube is shakmods tubing 10mm inner 12mm outer, the same stuff as EK tubing, but a fraction of the price, if you buy it in bulk it works out 50% cheaper.
Regular bitspower fitting or ones made for hard tube?
No idea, however one of the pumps has picked up a high pitch whining noise when its running, so will need to drain it out and replace it regardless :(
I think it looks great as is, clear distilled looks real clean. Perhaps one loop clear, 2nd loop red.
I'd just like to thank Mick at Mayhems for releasing a long-term aurora product.
Time for a deconstruct to change the pipework to accomodate the new liquid.
Damn you Mick!!!!
Haven't seen this log for a while but you've done an awesome job. The piping is awesome, looking forward to seeing it back again.
Nice one :D
That is a stunning build. I can see me investing in some acrylic tubing in the future. Hows the rig run, or are you still waiting on bits?
Good job so far :)
And this case is a monster, one of main reasons I like CL so much :)
How tall is it? My S8 with pedestal is around 80cm including casters.
