Project Blue
Ok,what is this white peace of something.....no one? This is .999 pure silver :D And this will become silver kill coil :)
Let's start
Firs the tools,usual ones for my project
The silver is very hard after the rolling mill,so need to become softer.For that reason one more tool is added
Cutting
Filing
Even more filing
Scraping
One side ready,marking the other one
Cutting
More scrubbing
Time for sanding.I will start with 600 up to 2500.Reason for that is,silver is very hard to polish.Especially the pure silver is almost mission impossible , always goes back to his original colour.
Sanding with 2500 sandpaper by hand
Polishing
Success :D
And the final product :)
That is all for today lads. Hope you like my new silver coil. Stay tuned for more :)
Hi guys,
I manage to finish the fans today,so here's the photos
And mounted on the rads
Hope you like the photos :) That is all for now :)
You wouldn't happen to be a Marine Engineer to trade would you? Just seems like that sorta thing that fits, all that manually filing etc. The g-shock also ;)
:)I wish to be one,but I'm not.I use to work as a jeweller for very long time (not in Uk) ,that's why filing and cutting are my passion :) By the way I'm a big fan of your project Midas.That gold theme is really awesome! I'm planning something in silver for my next project :)
I just managed to paint all the parts from my water cooling loop. Took me longer than I expected . I found,that painting acetal plastic is harder than doing the same with other plastics,without proper preparation. Any way,results are good :) Currently I'm assembling all the parts together. I'll do some quick leakage tests to make sure everything is in order. So the photos will come soon :)
Small update from Project Blue :)
Some goodies arrived today from Holland :) Beautiful fittings from NANOXIA,and Darkside UV led strips.
The case start getting shape. I manage to install the rads,the pump plate and some of the led strips. Hope you like it :)
Bigger update will be soon ;) Stay tuned :)
Hi lads,
Here the photos of the EK parts painted,and ready to go in the case :)
4.4_zpswl9jj82n.jpg.html
Still have some more ideas for this project ,so stay tuned for more:)
