Project Blue
:)I wish to be one,but I'm not.I use to work as a jeweller for very long time (not in Uk) ,that's why filing and cutting are my passion :) By the way I'm a big fan of your project Midas.That gold theme is really awesome! I'm planning something in silver for my next project :)
A jeweller...special skill set that, explains your attention to detail now. I'm a marine engineer and all that filing looked like something I'd do, just because you can (you know what I mean). Glad you are a fan of Midas, she's getting a make over and hope to progress it more soon.
Look forward to seeing this one finished, the shade of blue you are using is awesome. Next project in silver, sounds good to me.
Enjoying your log anyway :D thanks
Thanks mate! Currently I'm cutting acrylic tubes :)Hopefully I'll be able to match this awesome blue colour for my coolant!
Hi guys,
Still doing the tubing.As you can imagine there is a lot of cutting,filing and sanding :)
Still waiting for few more extenders and 90' angles,so I decide to finish the last led strip
I can't resist and will share one photo before I finish everything :D Excuse me for the bad quality of the photo,but I believe you can get the idea :D
Looks awesome mate! Mayhems help with colour matching (if coolant isn't sponsored) thread here: http://forums.overclockers.co.uk/showthread.php?t=18344603&page=36 in case you haven't seen it already. The blue featured in the video looks fairly close already!
There is no sponsors in my project.Looks like the blue in the video is same or at least similar to my colour theme,but I will try to contact Mick.I didn't know, that there is a thread for Mayhems coolant Thanks :)
The UV light pic makes me it all come together great.
I have a question about your res bracket, is that something you made yourself?
Edit: I just looked back at your OP, I totally missed the bracket image ! I thought to add something similar to mine but on the other side of case.
Yea,It's coming with the res ,but personally I prefer something not that visible.The other problem is,that doesn't stay strait.I need to use washers to make the reservoir levelled.
Hello everyone,
Small update today from my project :) I managed to install new RGB LED strips and all acrylic tubes. Still waiting for two rotary adapters to arrive because I ordered the wrong degrees adapters last time :mad:
I decided to clean the system now and check for leaks.
There was a small leak from one of the extenders on the pump, but nothing major.So I will leave the cleaning solution for 12 hours, as recommended.
I still have something in mind to do ..... but you will see it when done: lol: I hope that I will finish next week Stay tuned for more :)
Looks boss! :D
Gorgeous build. Love that blue colour, does it have a matte effect/ not shiny. Played around with Halfords paints but they were to shiny for my liking. Awesome work.
Thanks lads:)
How did you find these to work with, any visual difference in person to picture as I'm looking for a good quality spray.
It is a low pressure spray paint,and very easy to work with. Planning to use again mtn 94 for my next build.
