Project: Clean
As i said elsewhere Dom, case looks great :)
Shame they couldn't do the PSU, why wouldn't they get the paint of exactly!?
The E-mail from tom said this
We have one issue, the coaters couldnt do the PSU covers, they couldnt sandblast it as it was too fragile so they didnt want to risk coating it as it would have come out bad.
Unfortunatly this means its still as it was as standard..
:( but hopefully the wetsprayer can do something about it!
If not I will have to do give it a go :| It will come out CRAP :D
Ahhh fair play, least they didnt do it and it come out crap!
The revolution PSU's do look like they got a textured surface, dunno if thats just the effect of the paint though or its actually like that.
Sure you will do a good job on it though :D
Looking really nice so far. Been a long time since I've seen a white case that does not too clinical, be keeping an eye on this thread. Good luck
Haha Cheers Andelusion and NathanT :)
well it could be looking "Fresh"er if I had more money ;). I decided not to braid my PSU with the current braid as I have found better quality braid! I will be using, my current braid for my OLD SKOOL Project which I will be working on in the next week :P.
As I am moving out in December/January. All avalaible funds are going towards moving out and the PC after
Hi guys
I got a real Dilemma about the braid for my case.
I originally bought some white braid from a shop in Scotland and as its poor quality, I want to buy new braid! But when looking at the cable I already braided, white braid looks a bit.......Clinical clean!
So right now I can’t decide if I should carry on with the White braid or get light blue braid (fit in with the Gigabyte mobo + ram or go for mixed white + blue braid.
My Mrs even said, why don’t you have half blue and half white.
Please let me know what you think.
Cheers Dom
Get the blue white striped, you know it makes sense ;)
Don't compromise on this build mate, even if it takes you an extra couple of months to complete it will be worth it :)
of course it does Pauly ;)
Haha Marine Iguana! :) everybody says that
and thanks Greek.
anyway here is some pictures with the mobo inside. Ordering my Blue and White braid today :) well the 4mm for now.
The White braid does not cover propley :) + the fan will be changed for an Enermax Cluster REAL soon!
