Project: Cool Dragon
O.k. so I mounted the radiator on the top of the case.
There was barely enough room for the 8 pin power cable ;)
With all the blocks installed and all together :D
I mounted my pump with some soft rubber stickpadded to the bottom of the case :D
With all the tubes
Ready for a leak test
Leak testing
I thought the GPU block looked great ;)
Crappy news now though, the machine won't boot. I am going to have to drain the whole thing and test all of my components because I have tried all of the obvious stuff :(
Yep, I had everything air cooled before so I know it works. There were no beeps but I got a engstrom0304 round and we interchanged my stuff with his (etc tested ram, board, CPU etc). Motherboard was the problem. RMA time.
any more news on the mobo yet?.
Well, I have opened an RMA request for the mobo and the GPU because after more testing I think the GPU is also faulty (or is faulty instead of the motherboard). My warranties run out early Jan so I am running around seeing if I can pick up a GPU for a tenner to test the mobo. If not I will send both GPU and mobo off and risk paying the fee to get one of them back if it is not broken.
dam, everything was going so well now this!. do you know what could have done this?.
Not a clue :( Possibly removing the vram adhesive heatsinks from my 5850 but otherwise not sure. I have got a friend coming round tomorrow (hopefully) and I will test his 5850 in my mobo so I can see if the mobo is broken.
