Project: Cool Dragon
Tiny update:
I have just bought a couple of Noiseblocker BlackSilentPro PK3 140mm Fans as they are ridiculously good spec, have been reviewed well and have a good static pressure which will be very beneficial for my densely packed fins. I will run them through my fan controller though so they don't burst my ear drums XD
O.k. guys, I really want something to do in the mean time (PC wise) so I am thinking of braiding my 24 pin mobo cable, 8 pin CPU cable and my two GPU cables with 50/50 black and blue sleeving. I will also use any extra sleeving on fan cables+front panel cables etc. What do you think?
I have started braiding, but the sleeving isn't great quality. I really bought it just as something to do while I wait for the 5850 so it is for filling that purpose but it is a little see through with colourful cables behind. I suppose you get what you pay for and to be honest I didn't pay a lot :p . It will do for now but I think in a few months time when I actually get this PC working and some more money I may re-braid with some more expensive stuff.
Will put some pictures up tomorrow.
Braiding is something I am thinking of doing in my current build (as the wiring looks awful). Any advice on where to get decent braiding (or what to look out for)? And what tools are you using to get the plugs off?
Well, to get the plugs off I used two paper clips. Took a while to get the hang of it and although everyone on the internet says don't pull hard a couple of my pins only came out with a slightly harder pull. I have sent you a trust message.
Thanks for the quick response.
Paperclips!! Do you have a link on how to do that???
What I am looking for is to to group runs of cables together. I thought of doing this within a single braid. Your thoughts?
Sorry I meant staples lol. Well, you have to straighten two staples out with pliers and then insert them into the pin hole, either side of the metal pin. Push them all the way down while pushing the cable up, and then once they are all the way down pull on the cable and it should come out.
