Well that was 3 days offline i won't forget in a hurry hells bells i am patient but even i allmost snapped
Morning Paul
When the case is ready is ready and i grab some new cards will probably do the quad top and 2 dual in the lower psu bay, not entirely sure of the outside rad. It looks ok but not 100% stuck on it the fan noise is pretty good considering and that will improve once i get around to installing the acquero and can moderate the speeds properly
Hi Mr Cleeecooo sah, yeah it is kind of "beastly" looking not sure if it will stay for the final build but its definately different
Thanks for the kind words Mr w3bbo sah, its still a work in progress and am thoroughly enjoying it (well apart from the last 3 days)
Cheers Stinger53 thanks for the comment and for taking the time to look
Mr May sah, blimey you've but a lot of time and effort into thinking this one out, have only just gotten back online so will have a good look and think over the suggestions, am liking the idea of moving the psu good thinking
So why 3 days
I started cutting up the 700d to fit the sr2 motherboard tray friday morning, what with one thing and another i realised my trusty dremmel was not upto the task. Cue a visit to wilkinson and an £18 angle grinder probably my best purchase of late cuts really well and importantly a lot quicker than a dremmel.
Was going to move the build into it but am going to wait until i have it finished and sprayed, useing the 800d at present to test and play around with layout untill i am 100% satisfied then i will move the gubbins over.
By far the biggest time consumer was filling and bleeding this revision 1.3 koolance res, the rev 1.3 supposedly helps improve the filling and bleeding process .... good grief what the heck was it like before??
It started out well and bearing in mind this is my first build the pump started making a real "grinding" noise. I panicked and jumped online to order a new one not realising as a friend explained "you idiot its just trapped air" thanks Mick you saved me a lot of time trouble and money
So once that was out of the way (best part of a full day to bleed!!) i thought about the triple rad on top and got to thinking it was a bit of overkill for the cpu and mobo cooling, so replaced it with single depth triple pull only which has not made ant difference to temps cpu 100% load 3.8 oc 49 degrees and the wc 480 845 core and 34 degrees ... a good day.
So thats what i have been upto, still a work in progress and occasionally frustrating but still hugely enjoyable and the satisfaction of getting it right is a win win
The case mod still needs "finishing off" then spraying but am well pleased with getting the sr2 mobo tray inso easily
