Project: Danger
Starting to oc slowly and pleased with the cpu so far got a feeling the gpu temps are going to be quite high once i work them upto 750 or so on the core but its getting there and well chuffed
any updates ttb? also, is this case all metal? as I'm considering getting it when I finish my upgrades and powdercoating it white and mybe with some orange :D
Evening KiiYzOo :)
There will be some updates in 3 weeks, think i have finally got the funds for an sr-2 ... time to put those 2 xeons to work methinks :)
Its just a bog standard 800d with an sr-2 motherboard tray which i thought was a good idea given the amount of mobo changes i go through, its metal yes with "stone" effect paint works really well though.
Once you have everything in place rather than spend money on powder coating why not spray it, providing you take your time and plenty of masking tape it should work out well at a much lower cost .... £7.50 and a roll of tape to do mine then there was the red if you want to highlight the effect :)
it's probably gonna be between this, the new cm storm striker (white storm trooper) or the tj07, with porbably dual loops and maybe inverted atx :)
Cheers for that Phill :)
Borsch go ahead and do it, this was my first wc build so if i can do it anyone can. All you need to remember is check, double check and check again you will be glad you did :)
