I did bud but the mods wouldn't rename it. If any read this and can change it can you rename the thread "Project Dovakhin"
Did you report it? Just report the first post, one of them will sort it.
loving the spray, might have to look at getting something done on mine in the future, looks awesome!
lovely finish to that case due
very shiny
To be sprayed black by the Auto Sprayer was £100(ish). The actual artwork is costing a further £400.
Also a quick update, just got a water block onto one of the 7970, in the process figured out why they where so terrible with the original cooler, quite simply ONLY the GPU core was being cooled, everything else (The RAM, VRM's etc) was simply left open to the air, no active cooling in the slightest.
Temps now down from 96c in BF3 to 39c (Max) in 3D Mark 11. Can't wait to get the case back an get the second card water cooled, but for now it will have to do.
WOW! Worth every penny!
Thanks for the link to the painters site. Bookmarked in case my numbers come up....
Total price I paid in the end was £475, and yes worth every penny![]()
Wow, was it really worth it?![]()
Have you tied the fans outside of the case ?
Sounds like the case is vibrating.
