Project Ethos & Cube - Desk Awesomeness
Sorry there hasnt been much of an update.
Life has been hectic!
But here is a small one from last night.
Sanding down the side, getting rid of the filler
Stained the Drive bay cover
Doing mounts for PSU
It actually hold the PSU in really well!
How it will look with the other PSU once I get it
Side is stained, but you can see the join unfortunately.
In person it doesn't look so bad
Screwed down the mounts for Mobo tray
With the tray
Then we had another issue to take care of, my Chair...
I needed to remove the arms, as they were not allowing the chair to slide under the desk fully.
So one would think it would be simple as removing a screw or bold.
But no... This one had an double lock mechanism.
So after some sweat and frustration the head got stripped.
Next thing... Drill it out, as I was over it!
Phew it came off!
After that it was finish fitting the middle rad
Had to counter sink the screws again
All fitted nicely
After that we made some little risers for the Res so that they stay above the pumps
Then back to finishing off the staining
After the stain is dry its varnishing time
Even the little risers get the treatment
Last thing we did was to fit the handles for the draws:
Measuring out
All done
That's it for now...
Hopefully do a bit more here and there.
Found a bit of time the other night.
Decided I would try laying the Vinyl...
Oh man it was a lot harder than I thought it would be.
Took about 3 and a half hours.
Prep, removing everything form the desk and making space
Rad mounts removed
Sanded down the desk, not much but just so its silky smooth
Put the vinyl over the desk just to make 100% sure its large enough
Did a quick cut out of the corner, thinking I can then just push it up and cut it closer after
Didn't go like I had imagined
Figured out another solution, make a template
Cutting out the vinyl... (In hindsight I should have made a template for the whole desk!)
Fits much better now
Laying it out
Going over the little back part
Not too bad, but unfortunately the wood had a cut mark, which shows in the photo.
It doesn't show in real life unless you look really hard
Carrying on, and going down
Finishing off the bottom section
Cut out for the middle Rad
With Rad cover fitted
And the mess that is perfection!
Next step is to run some black silicon around the edges to make it look finished around the edges, and to fix a few of my balls ups!
That's all for now :)
Ye some love it some hate it :)
Its hard to please everyone ;)
But you are just looking at it without anything on it.
It will look better once the trays are back and everything else is done...
Looking good. The carbon fibre looks a bit much at the moment but I think once you get the hardware mounted in there it will break it up a bit and look really nice.
Looking forward to seeing more
I shall try and reserve judgement :)
Amazing work by the way :cool:
