Project Ethos & Cube - Desk Awesomeness
Update time...
LED RGB strip installed, and testing it out:
Empty out the loop and install a drain line:
5x HDD's in and stickers removed:
Then some chiseling time:
Some cable tidying...
Decided to forget the stitching as there were some really awkward areas.
UV LED installed:
UV LED switch:
And some pics as it is now:
That's it for tonight :)
So The Baby Grand is almost complete.
Still have a few bits to do:
1) Replace mobo block with an EK one.
2) Clean out loop and re-fill
3) Different fan controller
4) Other bits and pieces
So got a few good pics done for now :)
Warning pic HEAVY!
Honestly I'm not sure...
A fair few bob, but I haven't calculated and dont want to calculate it :)
Ignorance is bliss (especially when the missus asks)
Not 100%...
Still need to change out the mobo block to a EK one, and running the loop around from the CPU to the South bridge, then into the GPU, so some more cable bending.
Clean out the loop and re-fill maybe with UV Green for a bit.
Also something to cover a bit of the HDD's, as I dont like them as just silver.
Might try some copper stone vaneer or silver stone, dunno yet.
And tidy up the cables hidden behind the gaming machine.
Lastly hide/sleeve the power cables going into the server so they are not like yellow/red and so on.
But yet its almost done :)
May want to add in another GPU, just because.
Love this build, did you finish off the last few bits?
Unfortunately not...
Although I have some good changes coming soon in the form of Dual Titans ;)
I have them and blocked already, but just need time to drain and clean out my loop and install them.
Also bring out the mobo and changing the block on the mobo itself.
I *HOPE* to do it this weekend but cant promise.
Man life has been so busy.
