PROJECT: FLAME ORANGE
I'm testing the paint job on a spare radiator I have :)
First two layers of primer applied after a 15mins rub down!!!!!! OH erm mrs!
My job this evening is to strip the PSU casing I have and prep that for orange painting too. I will update later.
So I got this unit
And took the bugger apart, it wasnt easy to get into the unit, I needed pliers as some of the screws were buggers! Mind you, your not meant to take them apart.
I removed the Antec logo plate from the PSU, I intend to glue this back on once finished.
Next job was to primer the PSU frame... but first I celotaped the rear part of the PSU frame as that has the connection info printed on it, I wanted to keep that info.
Finally primer time
Finally while I was setup I decided to put on two layers of orange paint to the rad as the primer was dry now. I have done the top side, once dry I will flip it and spray the other side twice too...
The orange is looking good at the moment. Happy with it.
wow... that orange is actually really nice, i used the same orange as the focus st, and although its nice as a detail type of spray, when i did my radiator it looked too.... ginger :/
that looks epic.
second picture down is my favorite though :o
