Project H1
HI
H1 owner here
is NF-A14 really worth it?
also how loud are those fans on the back.. aren't they to close to the metal? i imagine that being so close will create a lot of turbulence
Not sure if is worth it on the long run, the 140mm NZXT fan works just fine, the Noctua is more quiet though. Regarding the turbulence, the NF12x15 have rubber anti-vibrations pads so there is a bit of space between the metal and the fan, they are very silent too
hmm .. I'm considering it.. if its quiet on low rpm but can spin significantly faster than original nzxt fan it might be a good solution
i am surprised it even works @5.4 with that 140 AIO :>
