Sorry to bring this back from the dead! Any updates? I'm really looking forward to seeing the finished thing.
It's not dead! updates will be coming - without a decent camera atm - took some pics on my n97 phone but don't have the micro-usb to usb lead with me so can't upload them atm. There was a fairly nasty hiccup - the fill cap on the top had gotten some resin in the thread. I tried to get rid of it with acetone on a cotton bud and then scrape it off, but the thread got a little mangled. Then it was a nightmare to screw in the plug - it wouldn't seal unless very tightly screwed in. Then I screwed it in too tight, heard creaking, and then the copper ring/washed type port on the top shered from the solder and came off, leaving a hole and a small shard of resin came off, thought the resin top is okay. So then I defiled an old fullcover copper EK block for an x1900xt with a dremel, just to get a 1" diameter copper replacement port! Filed it down, bought an m2 countersunk drill bit and drilled and tapped 6 countersunk m2 holes for 6 screws to attach the replacement port to the copper box1mm thick top panel to resist rotational forces when screwing the fill cap in. Sorry I don't have pics - but have some very nice ones to upload!
thats pretty nuts. dont it wiegh quite a lot tho?
Yes, yes it does. About 30-35kg with everything in.
It's nice to see this in the Project Logs!
Sweet, OcUK has a modding section now!
Ah first i had no idea what was going on... but after looking and reading thro it... epic!
Wish i had the time to do something epic like this... Enjoy mate!
Out of interest could you not dip the whole thing in some sort of paint? or would that just keep the heat in?
Cheers!
I think he's planning on doing that later, though I may be wrong. Maybe powdercoating it, or something similar
Nah, no coating planned - don't want to hinder the cooling. could do with a proper clean though - the bead-blasting has only got down to about 1cm either side of the copper fin edges, so still lots of tacky burnt-on flux covering about 2/3 of the fins (but not very visible). might have to soak the whole thing in a bath of washing-up liquidy warm ater and set at it with a toothbrush or similar.
Oh, speaking of the cooling performance, I decided to attach the GPU block to the graphics card, so I drained the loop and decided to have a look inside the heatkiller cpu block, and it was almost completely gunked up - must have been the chemically melted bits of resin from the top port that came out of the thread. Of the 13 slits in the internal impingement steel insert, all but about 1.5 were completely sealed with plasticky goo and only about two 5mm thick strips were getting any water cooling at all!
Now it's been cleaned up and with the 4850 GPU in the loop as well, with the i5 750 overclocked to 4.2GHz using 1.43 vcore, it maxes out at around 55C in Intel Burn test iirc, and around max 50C in games.
Should have it up with me next weekend for good to do more thorough testing and get some pictures up.
