Project : Ive quit smoking so had to spend some £
I usually leave the loop running overnight for leak testing! Just the loop not the whole PC on(using a spare PSU & jump start using a paper clip)
So are you saying your pump was off while the whole PC was ON? For how long?
not longer then 15 sec.
I touched waterblock straight away and wasnt too hot
I felt hotter cpu/gpu coolers
i needed to connect a spare cable for the pump as it is molex and I use sata power cables...it turned out it had to be faulty as no power went to pump.
Make sure you have connected all the power cables properly first. 24 pin ATX, 8Pin ATX, 2x 6pin PCI-E power, HDD power and Data, and finally RAM!
time for a break
at the moment am looking for someone near me that has spare graphic card or psu...
can it be cpu fault ? fans are on etc but nothing happens..it can be cpu as well ?
What PSU you get? :)
antec 650
wasnt going to get antec but this one seems to be recommended a lot!
this thread has made me laugh quite a lot, but I'm looking forward to seeing how it looks when it all eventually works :D
shall I smile or slap you ;>
I almots always had some problems with this system....even unpluging one hdd could cause system not to post heh
was going to go AMD BD once goes for sale but maybe now will have to get something else sooner :(
