Permabanned
- 11 May 2011
- glasgow
lots of nice new toys there
shall I smile or slap you ;>
Good to hear!
My money is on the psu.
So how long will you need to stay off the cigarettes before the money evens out?![]()
whats easiest way to drain water from system ?
have new res/pump as well...
So what is your new res and pump?
There are many easy ways to drain a loop.
It all depends on the the loop though.
Some with T line/ drain line at the very bottom of the loop.
Some use the fill line as the drain line as well, but have to tip the case upside down.
Some use Quick disconnects.
I first started with a res/pump combo(DDC with XSPC res top) and did the tubing long enough so I can take the pump/res out of the case and drain by simply unscrewing the tube connected to the pump.
But now I use Quick Disconnects.![]()
sorry to see your luck hasn't improved over the years![]()
all is working now how it shouldglad to see you got most of it up and working![]()
-gives gold sticker- ;D
