PROJECT: MAGNUS AQUA DOMUS!
Did some flushing and a little leak testing today :)
Phobya Nova 1080, XT360 (XTX360 is in use atm) & Supreme HF Cu getting some warm water from a spare 18w DDC I have:
Radiators could do with a blow out before fitting:
That block, just stunning:
18w DDC with the most retarded top I've ever seen, I had to route the tubing into the fill port as if you use the return line it just pushes air bubbles directly back into the inlet :confused: :
A final flush with 2.5L of De-Ionised water:
As she sits just now, exposed in a bench table shoved in a cupboard next to the boiler :(
Don't forget the potential £900 CPU (top line IB-E) that is getting added late on this year, as well as the un-doubted GPU changes (In the last year I've owned around 9 GPU's :o).
Plus if Titan doesn't carry an absolutely retarded price tag then I may be moving sooner rather than later ;)
One day I'll have a job... And a build log like this will follow a year later :p
(I'm not a sponger, I am in college full time :()
You'll get there bud, I spent 4-5 years with college and apprenticeships :)
Its all been gradual purchases over the last 8 months or so building up to this point.
I'm really hopeful of at least getting some parts moved over next weekend, but I can't really move anything until I get the Mosfet block for the motherboard, as it would be pointless fitting it to have to remove it again :p
Edit: this week I WILL be cutting the rear side panel and putting some grommets in for the 1080 tubing :)
Nope not at all, if I didn't have a kid on the way I could have easily doubled the budget by moving to hex core and buying an LD case.
Watercooling alone is currently sitting just over the £500 mark.
Just waiting on deliveries now guys, hope to have the bulk with me by the weeks end.
Now on a mission to get it all done and benched before titan steals my thunder :o
