Project : Monolith
Love the towel, although the colour doesn't quite work :)
Seriously, great build and gorgeous colour scheme. Love the colour of the braiding too.
Cheers, yeh the towel wasn't doing much for the temperatures so i removed it !
Thanks for the positve comment :)
Brilliant build there.
You get those braids from Chilled PC am guessing ;)
Yes, from a 'competitor' !
Quality built. Well done m8.
A bit more work done today :)
Fitted the illuminated floor.
I'll take some shots of it in the dark later, and post them up.
Leak testing has been done, and safe ( ! ) to put my 5850s' back in the case.
I photoshopped a small design to cover the fugly crossfire bridge. It'll do until i think of a better way to mask it.
The 'pump room ' ;
Random;
More to come......... :D
Cheers
Mark
Had a couple of people ask about the illuminated floor via email ( which is always welcome :) )
So here's a basic guide to making one.
Step 1
12mm right angle cross section.
You can get lengths of the stuff from most DIY stores in aluminium or plastic. As this was not for strength, put simply to raise the floor, plastic was sufficient ( and far cheaper as i had to buy 2.8m of the stuff )
Simply cut to size with a Stanley knife, and in my case, spray the outside edge with black paint.
Step 2
Fix some of my favourite SMD led tape, available from Phenoptix, to the inside face.
Dead easy as it is self adhesive.
If you position the top of the tape 3mm from the top of the plastic cross section, then the 3mm acrylic floor will sit on it flush.
Step 3
After experimenting with different options, i found that a simple piece of white printer paper acts as a great diffuser for the light to even the spread out under the acrylic floor.
Step 4
Secure your cross section to the case, and the acrylic will rest on the SMD tape.
Step 5
Sit back and admire your work :D
The finished article :)
Daylight :
Dark :
The pictures have an orange tinge to them, but i can assure you its red :)
Cheers for looking, and i hope this little guide helps :)
Mark
Montage ;
Thanks for posting your comments throughout this build, all very much appreciated :)
Cheers,
Mark
