Project: Plasma Cannon
Sponsored by
Hi guys as promised it’s time for another build log update finally got time to finish cutting up the 4 barrel rings and got all then drilled and a shallow countersink on them just so I can secure then together for the grinding.
One of the ways I can make sure I don’t go too deep is by using the head limit (black item on the top right corner of the above image) this is usually found on most bench drills or small milling machines like mine. Unfortunately just when I need it this happens….
That piece of steel 15mm thick in its narrows area! Shouldn’t of broken oh well I ended up using the Z axis rule on the side and sent off for a replacement part as its still within warranty. Onwards now cleaned up the paper templates with a little white sprit and an old rag.
Then secured all 4 rings to the baseplate ready to clean up the internal parts then secured a big plate of aluminium so I can increase my working area sand between another small sheet of trusty cardboard so I can have the rings freely move onto of the plate and also reduce the amount of scratches caused by the bolt ends on the underside.
He we go…
In no time it starts to shine but still needs some more doing.
The insides finally came up very nicely with the final pass with a 120 grit drum.
Now the insides are done I have to disassemble it so I can do the outside. A little mark on the hidden area will allow me to line it up again.
Now the outside needs to be done.
Finish countersinking the reaming holes. Taking care not to go too deep as I haven’t got a head limit.
Ok now that’s done I need to buff up the front of the ring. As you can see from the above photos the front of the ring is a lot darker then the grinded areas I presume this is some kind of manufacturing side effect when the metal was fist cast. A sheet of wet/dry paper and a lot of rubbing should remover this darker tint and reveal the true colour underneath.
Messy Work using wet aluminium oxide paper.
And finally Its all shiny.
Onto the barrel wrap. So decided to remove the frame from the body (seen in the previous post) so it’s a lot easier to work with. This stuff is really thick and tricky to bend to the correct shape.
But with a lot of elbow grease and a solid hammer it slowly went into shape.
Sadly I am forced to bolt it down at the sides but its not too bad (I will improve the countersink at the finishing stage)
Typical my hand drill has ran out of power so back on charge and time to show you hopefully what it will look like in the end placed on
In the meantime might as well cut of the barrel sight covers
That’s not all for now! Those who skipped to the last post I have updated some of the design shots on the first post of this thread
Enjoy!
Hey,
That looks quite nice - I am impressed with all the manual work you have done, especially with the jigsaw.
The clamp on your clarke mill is a weak point, i have the same mill and the exact same thing happened to me.
You need to watch the Nylon gear inside (spur) it has a tendancey to chew itself up
Mostly I just use the CNC router now to make stuff, If you need any small parts making give me a shout I should be able to help you out.
keep up the good work
Craig
This is one of those where if I saw this unit built and working:
- I'd demand to see the creator
- Shake their hand
- Buy them a beer of choice
- And request them to talk me through each individual section
Brilliant concept idea and well thought out. It's surprising just how each section works so well.
Great job!
Thanks guys :D glad your enjoying the log
Hey,
Craig
Thanks dude interesting about your head limit breaking too must be a batch of poor quality metal or something. I better check out my gears soon see if there ok :eek: . I also found a add on that is possible to replace the gears with a belt drive this is suppose to be a lot quieter and can get slightly better rpm. Thanks for the offer of small parts :D its really appreciated I will pm you if I need anything
Superb, roughly how much is this going to weigh?
I know its ally but even so that looks a lot of metal there!
I need to get some scales at some point but I am starting to get a little worried about the weight and the case is barely 30% done! :( now planning to strip down the case and drill/mill out unnecessary metal just before I send it off to be anodised. hopefully I can still use the clear plastic rods as a stand without them snapping.
- Shake their hand
Great job!
You got yourself a Deal! When done I am hoping to take it to a few LANS or competitions :D hope to see you there
should have another build progress soon guys :p
No worries, Always happy to help a fellow enthusiast!
I have been looking at building a custom case myself but Just cannot settle on a design.
If you do want some parts and would like to see examples of my work just let me know and I will shoot some pics up.
as for the spur, Its not super fragile its more of a design as a weak spot so not to damage anything else.
I am aware of the conversion kits but would rather keep the saftey of an £8 gear than a £100 motor.
Good luck with your build!
maybe make some detachable attachable wheels for sliding in to lan :) specially if heavy!
Sponsored by
Hi all time for another update this barrel section has a lot of work in it but its starting to pull together now finally managed to get the wrap fully around a secured without the need for any clamps (that was tricky!)
Nice! Though I do agree it’s a little messy with the cut outs and dodgy failed bolt hole but all of this will be hidden away! Read on
At this point I couldn’t resist fitting the barrel back onto the frame to show you some the full thing so far but still a lot to do. And yes it does seem to dwarf my 2 seat sofa not many PCs can say that :P
So in the previous post I showed you the sight brass plates and here they are very roughly cut out but I don’t need to be too accurate as intend to grind them down to match the aluminium.
Ok clamped down ready to be drilled
2 basic bolts in there to hold the plates but theses will be hidden from view once the top plate is made
And then a quick clean up on the drum sander on my milling machine with some and filling to get those tight corners. The last thing I will do with the barrel is to polish it and this sight will also be polished at that time.
I'm not fitting theses until the wrap has been polished but may as well prepare them ready its the fine aluminium mesh for the vents in the side of the barrel.
After a few coats they don’t look do badly but I think it would be better with a bit more of a bulky mesh, what do you guys think? Any recommendations on a type of mesh and were to get it from I need a sheet approximately A3 size to cover all the holes.
Ok so the barrel underbelly this is mainly aesthetic but will also support the barrel end in the cradle and will be one of 2 parts on the barrel that will be red.
Ok so start off with an off cut of 25mmx 50mm box section with 3mm wall little bit smaller then i was intending but will cut down the weight a bit
Now 3mm box section is very hard to bend and i don’t have a press so my plan is to mill down the main side so i can bend it to allow it to sit snugly onto the underside of the rounded barrel wrap. I should have waited for my 20mm milling bit to arrive but this 10mm bit did really well. My mill is slightly too small for this kind of item so had to mill one side then the other but that wasn’t too bad as long as the vice is cleaned out so not stray swarf misaligns the work piece.
Ok that’s the one side done as you can see in this shot the one side is now a lot thinner now time for the other side this time I only wanted to take a little bit off as I wouldn’t need to bend this area much and I will need to tap it later
Only slight reduction on the top down to 2mm from 3
Now the steps on the front were milled with a 5mm end mill (take another look at the 3D show too see what I’m trying to achieve with this)
As I think it will be difficult to brush this once it is bent I decided to bush it now using a combination of the drum sander and aluminium oxide paper with a give so I can get the grain going in one direction only. After that i cut a long slot down the middle and bent the box section using a vice.
Hopefully this will look really nice in red!
The end cap for this is a small cut out of 1.5mm aluminium and I’m going to braze it onto the end of the box tube. This is the first time i have used a welding torch since collage and my first attempt didn’t go quite to plan. I ended up melting the corner of the aluminium too much and deformed the shape tricky too see how hot aluminium is unlike steal it doesn’t go red or white hot it stays silver even when melting so this was my first attempt. (sorry for the blurry images it’s kind of tricky to use a camera while doing this!)
But the small torch wasn’t given the heat I needed so I switch the head over to big roaring flame!
Ok so attempt number two went successfully as you can see on the left the join was good but on the right I got the end piece too hot and melted the corner.
A quick cut down to make it easier to grind
Now for the grinding was a little worried here as it looked like the joint had cracked but with a bit more grinding all was fine.
Now in place I drilled at tapped the inside to secure the box section.
With a little hammer encouragement I forced the wrap snugly onto the box section
That’s all I have time for now see you guys soon
