- 19 Jan 2008
- Sunny Wales.
Ok well i had some parts come today so i made a start on the Lian case side of the build. Iv also traded my 4870's for a X2 for a little extra room. Im just hoping the 8x8 2.0 PCi lanes dont hold the card back too much. Anyway after about 2 hours of taking it apart i finally had access to the mobo to start fitting the NB block. It was getting towards 70 in game so i thought its a worthwhile job while its all apart. The dfi nb heat sink is a handy little thing you can remove without taking the whole lot off so with it cleaned up i went and fitted the block which was pretty simple.
Block is nice and shiny.
Also to get the water from the radbox to the case im using these PCI plate connectors.
Iv also gone with webbos advice kinda and swapped the S-flex in the case rad out for some 20mm low yates that iv 7v modded so they run silent. This rad will only be cooling the X2 and NB untill i can afford another custom painted PA120.3 for the radbox. I also did a little modding so it should flow a little better.
Comments.
Comments.
