Hello guys
I decided to post a few pictures of what I was doing during last week.
The rig does not look as I wished yet, but there will be some changes, as I mentioned.
Including new CPU, a 4790k (EVGA confirmed newest bios allows new CPUs).
As you see on pictures below GPUs are very spread from each other.
I burned 1 GPU before because I couldn't see the air bubble the size of my thumb, so this time I planned earlier in order to avoid it.
Problem is, now I needed to get a 12 cm SLI bridge which may be to short after all (by around 5mm). I hope it will fit though, otherwise I will need to re-do the whole loop.
Anyway, pics below.
1. GPU 1 and 2 installed:
2. CPU Block installed:
3. GPU blocks and top rads installed, cable mess:
4. Left side rad installed:
5. Preparing for leak test:
6. Mini air bubble I mentioned in one of GPU blocks:
7. Moved fan controller to better slot, easier to route cables:
8. As it looks now, cold cathode's installed between the rads on top and in front, adding some glow:
As you have probably noticed, I have installed taller case top (38mm).
This is in case I ever add another GPU or change the rig entirely or to add fans on top of rads.
Next changes will come slow again.
1. Fan extensions in 2-3 weeks.
2. S8 Pedestal.
3. 4790k.
4. Cable management - final changes.
5. A few SSDs. My current OS ssd is getting old and sshd's are even older.
So that's it for now, the listed changes will come over next 2 months.
Appreciate your feedback as usual
EDIT: Baron C, the mobo plate have holes for anything up to E-ATX ( not HPTX, but you can opt for different motherboard plate if you want that format - but say goodbye to E-ATX motherboards then ).
