Hey guys
I received the delivery today and did some fan painting, un-packing etc.
I did some cable management with the extensions I bought, but it's not worth showing really.
This is ridiculous, I got red cables, but some are in dark red, some in lighter red etc, PCI-E 6 pin were just horrible to fit. On the other hand, motherboard and cpu cables fit perfectly. BitFenix have to seriously work on their production and quality, because this really shouldn't happen.
Anyway, I will be changing those cables sometime in the future.
I've added second GPU, mostly to see how the case looks with 2 780s.
I used PCIe slot 5, to give first card more room to breath, so temps are pretty good.
One weird thing, apparently this new 780 clocks better than the first one and at lower voltage. I think I should use it as my primary gpu, when I start building the loop. It's not much, about 14 mhz on the core/memory but always something.
About EK PE rads:
I like them very much the way they are, so I won't be painting them after all.
The matte black finish is just perfect. Also, they are very light, I was surprised.
I will start assembling the loop as soon as I get some tools to cut acrylic and OCuk stocks the pump/res combo I wanted.
Few pics of the stuff
1. These boxes are good for playing mahjong
2. Some water cooling gear, another 780 and MOAR FANS !!!
3. Not so empty anymore
There will be some smaller updates soon.
Loop is still on hold until my pump/res is back in stock.
