Colin, some pics for you
Unfortunately when I put side panels on, windows reflect light and all pictures look moved so sorry, but won't be posting those.
Instead I made a few showing areas I will be working on, mainly cable management and left/right side view without panels.
1. EVGA also fails sometimes. Like here, I got this nice I/O panel/shield. A pity it's for X79 Dark:
2. Most PSU cables are to long, so I managed to put them above PSU:
3. And behind this side panel. Also showing how many options I will have for routing the tube when I instal water cooling. Also, most likely position of a water pump (next to the fan).
4. Right side view. In the back of motherboard panel you can see very nice feature, a cutout for CPU power cable.
5. Left side view. Shows all the fans I have currently installed. And I can't hear them at all. Only thing I can hear is GPU when it's under load
That's it for now.
Next week I will be sorting some cable management, mostly fan cables - I bought a Zalman FC5 controllers and some 3-Pin Y splitter cables for the fans.
I'll post pics when I get the stuff (this time will try to make some during work, not after
Cheers
That's it for now.
Cheers
