Thanks guys
Well im thinking of adding a few new things to this system because after Christmas I bought a new tv with the money ive saved since finishing this bulid so i have around £500 to spend Max but would like to keep things to a minimum because Im also saving for somthing els...
I have a weeks hoilday from school next month so i have a month to decide but i need YOUR guys help
, I want to do more modding if possable and try and make this bulid much cooler and professional.
Im thinking of getting rid of the drive cover i made because its made a lot of problems trying to fit the pump, DVD drive and HD
and also I cant screw in three of the bay covers without taking mostly the whole PC apart
but i need somthing to cover the bay left side because I put a big dent on it when it way lying on the floor and I dropped a baking tray onto it :-S
Things I am thinking of doing atm...
Getting a waterblock for my motherboard + MOSFETS so that
I can overclock the CPU safley.
Finding a way to cover or sleeve that ugly SLI bridge.
Getting the Corsair PSU replaced again because that high pich whine is getting worse and anoying, any ideas?
Maby taking out the DVD or getting it replaced drive because it makes some not very good noises and I dont know if OCUK will replace it
Getting 2 90 D bitspower fitting for the top of the rads so that I can move the rads closer togither without the daft angle so that I can put my case window on !!! properly!
Getting some Liquid metal for the screws for my top window because the holes are stripped ??? (Don't know why) so that will stay on with out tape
I dont know if i will Sleeve the cables on the PSU with my MDPC-X blue and black stuff or just leaving it and seling on the sleeving ? what do you think?
Painting my MB backplate thingy, GFX PCI plates and the normal PCI plates because I forgot to send them off when i was getting the rest dont
Maby changing some of the tygon with some other clear tubing because its soft nd gets very soft and kinks easly as mensiond by thegoon plus ive also think it has staned.
Doing some kind of window mod or some kind of laser cutting design, maby mounting the window on the inside?
Placing one or two white LED strips on the bottom of the case to illuminate the white arcrylic abd to make things look more shiney
Some how remove the orange LED in my sound card but i have no idea on how to do this ?
Thats all I can think of the now anyway but I want you to feel free to post your OWN ideas
thanks!
