Project: SR-2 Desk
:eek: DAMN!!! That looks even more awesome in Powder Coat than I could have imagined . . . I honestly can't wait to see what this looks like once you start fixing it all together. This is one of the best builds on this site without a doubt. Outstandig quality of workmanship and it certainly looks like the quality of the Powder Coat hasn't let it down in anyway :)
Any chance of you finishing this before i die of old age? ;)
Cant you pull a "sicky" at work and get it put together? :D
you probably know this already but make sure you run a tap through the threads that have been powder coated, be a shame to ruin any thing at this stage
The powder has come out really well from what I've unpacked so far, you guys have seen what I've seen so far, as I work in Leeds during the week, I wont get this unpacked until this weekend...
From this Saturday I've got pretty much two weeks off...
As for running a tap through all the threads, I've planned for that, but the guy who did the powder for me, plugged almost all the holes when he coated it...legend. Ill still need to run a plug tap through it, but they all look nice n clear so it shouldn't be a massive hassle.
What a fantastic build! The SR2 is a serious piece of kit, what a motherboard! Nice rig when its all done :)
BUILD! (Picture heavy :D)
Quick apology, some of the pictures aren't quite right, as you can imagine. lighting was a bit of an issue :)
Right, so I basically gutted my room, took the bed out to give plenty of space to work, you can also see where I had to move my radiator to fit the desk into the room :)
First time I unwrapped all the metalwork...
I'm not sure of the rules on here for posting outside companies (if they aren't competitors etc) but if anyone would like the information on the Metal finishing company I went to, PM me, I couldn't be happier with them.
Firstly, I put on the felt strips which the glass will sit on
Cleaning out any extra powder that made it into the threads
Starting to get the brackets on and getting the frame together...
The switches go in as you assemble the frame
Love this photo...
Panels!
My flatmate laser cut me a matte black disk to cover the hole in the DVD drive, its simple and looks rather smart (about a million times better than the horrible sticker that was on it)
Now a "fun" part, group your PCI-e cables in overlapping groups of four and bind them together using a matching red thread.
Creating a core group which you can then attach the outer cables around.
(top part done)
This took a very...very long time, but was completely worth it. this was the most time consuming part of the build, but I used this approach on all the cables and they all now hold their shape without cable ties.
Starting the tubing :)
I then put the screen stand on, This is where the problem happened... I obviously needed to sand out the clamp so it would fit the newly powder coated pole. the clamp went on fine with some persuasion. However, the monitor stand armature which holds the screens did not.
Instead of making their screen stands out of aluminium, they are in fact made of cheese, sheared the clamp straight off the bar. I've got a new one on the way which has a more practical design which I can modify to fit the screen pole.
The moment of truth...
So currently the desk has all the screens just stood on the glass until I get the screen stand sorted, so I'll have some yummy pictures for you all in a week or so.
Current Clock/Cooling
Cpu(s) clocked @ 3.8Ghz
40 degrees Idle, 50-55 under load.
Gfx cards 45 Degrees Idle 55-60 under load
All with the fans at 70% (inaudible)
So the loudest things in the desk are the pumps so two D5's set to 3... its blissfully quiet.
Thank you to everyone who maintained an interest over the two years it took to make the thing, sorry for the wait, but I hope this makes up for it.
Sam.
That looks fantastic! Never a fan of red and black builds but thats more red than black and looks pretty sweet because of it.
Nicely done!
Screens, speakers and peripherals please!
What a ridiculous build. It looks absolutely incredible.
Bet that glass is a pain to shift for maintenance though!
