I'm glad you said that, as I don't really think they add anything to the design. In fact if I was to be honest I think they just don't look that good at all. Perhaps another variation could be done now that you have the scroll saw, maybe even using a different coloured plexi for the pieces so that they don't stand out too much, but it looks great as it is anyway, so I wouldn't worry about it.
Can't wait to see the finished product full of kit, it's been a great read thus far
True they look half arsed after the latest additions lol, theres a good chance I'll leave them plain holes but that's not 100% yet
, cheers Diggsy.
Thought I was in the clear with hiccups :facepalm:.
I'll try to keep this short but ended up going on & on & on like usual lol
The front copper mesh grill got more damaged than I thought when I drilled the final hole which is why it wouldn't sit flush to the acrylic, it bulges out by 1mm.
Tried whacking it into better shape at the time & then again today & seems nice & flat but not perfectly flat & it needs to be.
Decided I really like the copper mesh grill panel & going to alu for this front detail just would have been a come down for this, so ordered a 250x250mm x 2mm sheet & just in case I have more probs a 250x250mm x 1mm sheet so I can re-make it, but this time i'm going to go overkill with the clamping
, thought I did before with 2 G clamps nice & tight but I guess not, really couldn't believe it when it completely deformed, really should have taken a picture, it was so twisted out of shape I instantly thought well that's that then
but was using the kodak with it's internal memory with room for 6 or 7 shots.
I tried the original blank 3mm alu panel I made in the early stages of this project & it still fits perfect so at least the form of the case is still good, was getting worried it lost form some how
I'll be a bit busy tomorrow but if I get chance & I'm up for it I'll get something done even if it's just finishing off the strips & then I'll have to use gloves so I don't get dirt or grease on them, the more the copper gets handled the duller it gets & the strips have already started showing clear dulling signs
, so I ordered some brass lacquer for it to keep it's fresh look after I give it a re-brush & clean
The little copper vents are staying out of the build
, they just don't look good after seeing them with the strips & they'd be quite restrictive for air flow so laters to them
, I'll either leave the vents open or if I can think up something good enough I'll make something else but the edges got a good wet sanding so are near polished so theres a good chance I'll leave them as they are.
Just when I thought I was getting into some solid progress lol.
