nice pictures, what plans do you have for the tubing layout of the new case?
TBC, i'll talk about it later once i have these retarded gfx cards sorted
is the corrosion down to the bare copper on that block?
was that the loop using pure water that caused that? you didnt use any biocide in the loop or anything did you?
Pure water and biocide and dye. Corrosion is just the black bit, can't see any copper, but wiping it doesn't help
one thing i have noticed, my TJ11 is a real hassle for cable management, looking forward to seeing how you do yours.
I couldn't care less
The 07 was an EXTREMELY awkward case to deal with. In mine, literally nothing would work properly. The mobo wouldn't fit properly (all 3 of them) None of the 7 gfx cards i've owned have fitted properly. With the TJ11, setting it up was a breeze! Everything fitted beautifully
The cables will be awkward, but i think with some extensions, will be ok.
I have a few ideas but nothing set in stone yet, either way it will be far more of a hassle than a TJ07 due to the motherboard orientation.
are you planning on doing WC through both memory sets?
ofcourse!
personally a WC block on each memory bank with and the loop going
memory>CPU>memory would look sweet.
i'm thinking memory>mobo>memory
also
please don't think I'm being harsh with my cleanups, I am the only moderator of this section so the less work for me the better.
np
Keep up the good work mate![]()
Yeah, RJK, I thought that talking about faults with hardware was relevant to the project as it is part of the project.... It seems I misunderstood though, so sorry that I was talking about irrelevant stuff.I don't think you're being harsh, I just yeah, clearly didn't understand. So sorry.
Have you got power to the rig yet. It looks like you could do some tidying up of the loop in due course though
this was a quick "i need my BF3 fix now" loop
Are you going to mount rad in top or in bottom instead of HDD bays, pretty sure I've seen both done before.
kd
rad mounting is unknown thinking of maybe getting phobya 200mm rad?!
Clee
