Project: Temjin-S
what are you putting in the bottom with the rad? pump?
are you gonna stealth the bay res, as it will ruin the look imo
Single bay res has arrived:
I'm thinking of taking the black panel with the XSPC logo off so you can see the fluid from the front :p
I now have literally no money whatsoever :(
Should be getting another £200 next week and I will order sleeving then :p
Meanwhile, i'm sure i can sell something to get £20-30 for some spraypaints
And to check for any potential problems with my blocks, i'll setup a loop tomorrow, Pump, res, blocks and kill coil. Should hopefully find any problems?
