Project: Temjin-S
:rolleyes::p
Luminous panel is due by 3 pm :p
Hopefully the tubing, compressions and everything else should be in stock failry soon.
Also, what are all your opinions on getting a slim 240 rad. I know it's not needed but I kind of just want to add one - because i can!
extra cooling is always good, if you can afford it then go for it, but don't let it take money away from your funds for your sleeving :p
I think two rads in the bottom compartment just cramp up the compartment. I was going the 360 and 240 in the bottom in my old build but a 480 was more than adequate to cool CPU, GPU, mem and chipset all in one loop, unless the slim is for the roof which I think makes the top then look cluttered.
Back on topic - I am spending £17 on EK compressions. I'm thinking of buying 4 Bitspower ones so that all the things you can see (in the top compartment) will have bitspower comps on them. Then I'll use barbs for the rest. opinions please?
Just end up cramping the bottom compartment up, I was going the 360 and 240 in the bottom but put the 480 in which was more than adequate to cool CPU, GPU and chipset all in one loop, unless the slim is for the roof which I think makes the top then look cluttered.
the slim will be for the bottom aswell :)
