yeah it was ebay
also got offered an 800d
TJ07 is better
gonna see what this guy says first though
think I may do a matt white and orange build
EEWWWWWW!!!! Glossy white and orange
I will get a tj07 if I can afford it
no GLOSSHAY!!! white![]()
thankswish it was more vibrant orange
matt - 800d
gloss - tj07
this guy better send me a message back then
I wonder how hard it is to go reverse atx?
I LOVE THIS NEW MACRO!!!
What are the advantages of reverse atx?
I think if there's something unrelated to the build, you should post in my thread in the water-cooling section sober don't spam this one up aswell![]()
It's very easy, just putting the case back together differently. You need to order a custom backplate though to replace he current one. If it has a window already installed you effectively can't do reverse ATX.
You'd need to cut a window in the other panel as you can't just flip them. You'd then somehow have to "fill in" the original hole in the original side panel as it would only show the back of the motherboard tray.
Not a fan of the 800d, difficult to fit the stuff in that you can with a TJ07. I'd end up modding it to be just like a TJ07 which seems a bit pointless.
the only real advantage is that it looks nice, it would be cool to be able to see the gpu waterblock through a top window
alright then
I was actually meaning a different way, like this
http://forums.bit-tech.net/showthread.php?t=204450&page=12
I think that your able to do it a different way when the motherboard tray is removable
also the only reason if I get the 800d would be if I can't get a tj07![]()
aah I understand now
thought that you meant the flipping the case over type of method![]()
I wouldn't take such a nice rig to student accommodation
My room layout doesn't support it either :/
BWAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHALOLROFLLMFAOLOLOLOLLK
****E CHAPEL.
LOL
/5year old
