Project: TITAN 4 !!!!
Now this is gonna be epic, well jealous, wish i had your money Kaap :) the case is fantastic.
I wish I had my money, its all gone now, this is the last build I am going to do for a very long time.
I have just ordered another 2 AX480 rads, I found a problem trying to attach fans to the top of the case, the holes are only big enough to take rad screws so I need to attach a rad to attach the fans lol.
If I was to do a full water cooled set up, it would defo have to be in a little devil case! I can't wait to see where this goes.
Kaap what on earth is your proffesion/trade?
How do you afford all these tardis like machines :o
Not a bad shout on the blocks bud and so far the gains are very minimal under water. Under a chiller though, quite big gains ;)
When will you be putting it all together?
It should be up and running in the next couple of days, I am waiting for 2 more 480mm rads to turn up in the morning, I need to fit one of them to the top of the case so I can attach some fans. The screw holes in the top of the case are only big enough for the type of screws used by rads.
If I don't end up w/cooling the GPUs the CPU is going to have some serious cooling all to its self lol.
One of the reasons I have gone for a reverse type case is it means the GPUs are up the top out of the way and hopefully running cooler. On my corsair case where 3 of the Titans are now, the top one is very close to the rear rad causing them both to get a bit warm.
Good luck with the build and I'll be watching closely what you come up with spec wise.
A note of caution though and I post from experience, I'd turn the fans/stickers around so all of the Corsair logos are orientated the same way or you'll have Rossi~ to deal with ;):D:D
I had thought about the stickers but it makes keeping the cables neater the way they are.
If I peel off the stickers is there anything underneath.
Just fitted another ran and more fans.
It's pretty flat under the sticker but they do come off fairly easy if you warm them up a little. I just rotated the sticker as like you I wanted the cable routing in the right place.
What's the clearance like from the bottom of the PSU to the top of the 480, can't really see from the angle of the pics.
I have not tried it yet, but when I was looking at it earlier it is very tight about 1mm.
At the moment I have got a little problem with the PSU, I posted this earlier in 8 Packs section
http://forums.overclockers.co.uk/showthread.php?t=18498491
If anyone has any ideas I would be very grateful.
Looks like a standard 6-Pin PCI-E socket, if it fits then you should be good.
The adapter could have been wired with one molex using a loop but it appears it hasn't and does require 2 molex connections.
Google tells me there are a few others about by the looks of it. There must be a better looking one somewhere. Although i'd be inclined to use the adapter on 2 molex connections, hide it away and use a nice braided 6-Pin PCI-E extension cable.
Also, this may be helpful: http://www.techpowerup.com/forums/showthread.php?t=111509
Just order one + red braided extension to go with PSU PCI-E leads.
I think I will use two separate molex leads, there might be a bit of extra power needed on this mobo.:D
Thanks
Just posted some more pics in the OP
Does that chip next to the PCI-E slot with voton written on it look ok, I hope it is. Theres only one way to find out.
