Project: TITAN 4 !!!!
xD I wouldn't mind being like that also, it's a shame im a student and most my money gets spent on parties and social activities :(
I cant wait to be able to go crazy on a build :cool:
youve gotta do nothing but revise for a year then youll have more than enough for a pc next year
I know very well what im doing, how im going to do it.
We have another section of the forum called General Discussion. I suggest you go there.
Please take his advice.
Moving back on topic....:confused:
@ Kaapstad
Maybe you should try doing multiple ares 2 aswell? You'll have the best of both worlds!!
Very nice build indeed, one question why do you need 2 x 120.4 to cool just the cpu?
Thanks.:)
I have got 3 rads, at the moment I am only using 2 but will put the third in if I go for watercooling the GPUs.
For the CPU, I was only going to put one rad in the bottom but then I hit a problem. To get fans in the top of the case I had to put in the second rad, the screw holes in the top of the case are only big enough for rad screws.
@ Kaapstad
I would like a 4 GPU AMD rig but 2 x ARES IIs don't give enough performance to make it worthwhile. I might have another look when the 8 series launches and then upgrade one of my X79 rigs.
At the moment I can make do with this.:)
what do you use these rigs for? obviously its a hobby but do you do things like folding @ home or just lots of gaming?
As you say, its a hobby. I use them for gaming and benching, my problem is I don't sell my old stuff on. On my earlier builds I would just put everything together and dump the packaging which made it harder for me to sell older parts. Recently I have made the effort to keep the packaging for some of the more important things.
Don't worry I would happily take your old parts.;)
Really nice build, looking forward to see how it turns out.
If you want some honest feedback on the looks:
The only thing i would change is the colour. You already have red cables and can make the fans red using the clip on surrounds, the RIVE board has red on it also.
If you were to change the fluid to plain (clear) and the tubing to red transparent then i think that would be the cherry on the cake for this build.
But then again, how long are you going to look at it? Clock the danglies off of it and bench, bench, bench.
to add to this, i'd go with a tube Res and a double bitspower top, this would fill that gorgeous case some more and help tidy the tubing and also those uber cool AC Titan blocks and that build of yours is gonna scream WOW :eek:
It is not that easy to look at anyway, the side panels are held on by loads of screws lol.:eek::)
One of the few downsides to using Little Devil cases.
I think it looks awesome as it is tbh. Best to wait until you've decided if your going to put the Titans under water or not, no point in fiddling with it now. Just bench the damn beast and enjoy it :D
Btw how rigid is the case when its full ? does it keep its shape if you move it ? if that makes sense :confused:
