Project: TITAN 4 !!!!
I think it looks awesome as it is tbh. Best to wait until you've decided if your going to put the Titans under water or not, no point in fiddling with it now. Just bench the damn beast and enjoy it :D
Btw how rigid is the case when its full ? does it keep its shape if you move it ? if that makes sense :confused:
Very rigid, one of the problems with these cases is that they use screws to hold the side panels on. I think the reason for this is it contributes to the rigidity of the structure of the case.
That's good to hear. I'm looking at a few cases at the moment and i'm considering your one with the red interior :D i was a bit concerned that the panels wouldn't be strong enough for all the moving about i do with my cases.
This or pgi947's case to replace my cosmos :confused:
Depends on budget tbh, you could buy 3 phobya cases for the price of one LD, but the LD is such a refined case, the whole thing is very very well thought out - unlike the Phobya case.
Edit: Buy 3 phobya cases and weld them together :o
Not sure i can buy a LD it'll only be compared to Kaaps! and i aint gonna have 4 Titans! i'll be lucky if i have one :D
Maybe welding 3 phobyas together is not such a bad idea after all :p
How exactly is it a stupid way to spend at university? I have several jobs and i'm on a teaching placement. There's plenty more where that came from. I study and am already on track for a first with enough to settle down with a house straight after and I already got a house on my name in which mortgage is completed.
Tuck your epeen in, it's showing :rolleyes:
OP - Mental build lol especially with only one screen....better be a 30" monster screen :p
Any reason not to go multi monitor? With 4 titans, it's screaming for multi monitors :)
Red cables, purple coolant, blue fan edges.....my colour OCD is kicking in. Are you going to harmonise the colours in the build...make them a bit more coordinated?
Yes i use a Dell u3011
As for the Red cables, I hate them. at some point in the near future I will get some blue or black extensions on them.
Hey kaap what are your thoughts on multi monitors?
ive got my dell 27" was thinking maybe add another one.
Or get the dell 30 for the Titans
As i have one benq already
2 more will be £720 which will include the 3d vision kit
Or the dell U3014
2xTitans will be my cards
I don't know a lot about multi monitors, Rusty, Gregster, Andybird123, whyscotty and some of the other guys in the graphics section can advise better.
For a single monitor like the Dell U3014, 2 x Titans would be fantastic, I have been using a pair of GTX 690s on a U3011 for a long time. Some people say that is overkill, but its not really. It is the same as using two Titans, you can run even the most demanding games with very high settings. It is better to have too much GPU grunt than too little.
If you go multi monitor then 3 x 1920x1080 monitors should work ok with 2 Titans. If you want to use higher resolutions you may need a third Titan like Andybird123 uses.
As I say though the best people to talk to are the experts in the graphics forum.
