- 19 Oct 2010
The pictures don't appear to match the description.
Shameful he would do that to you as a close relation. That is an utter bodge.If it's wrong i am not overly concerned or goes wrong in the next few years there will be no drama and he will need to rectify as we know him as a family freind who completed the work.
Are there any trades out there that actually care these days.
The wood is laid in soil and rubble.
No airbricks are installed across the extension as its a solid floor extension.Has he blocked all the airbricks to your house as well?
Slightly redeeming - just stick a spirit level on it and make sure it falls away from the house...No airbricks are installed across the extension as its a solid floor extension.
That deck is sitting on rubble and soil without a doubt.Yep that is how it was done. The middle was filled with the backfill of rubbish but around the edges there was a small gap and the wood left off the ground. Again not an ideal picture but the joists none of them are sitting on the soil. We are talking a few mm (at best) but around the edges it was kept off the floor and clear. Not sure if it helps but it's all 30 year pressure treated wood
I thought the pic with the seats out there was CGI, looks good.I can't chime in about anything to do with the laying of decking as I know zero about it, but the end result looks fantastic for it. Hopefully it lasts for you.
Unfortunately "hopium" won't help at all here.I can't chime in about anything to do with the laying of decking as I know zero about it, but the end result looks fantastic for it. Hopefully it lasts for you.
What's their excuse for leaving all that crap underneath? To save time, I guess.
Honestly that's terrible and lazy work with the rubble dumping and frame embedded in it all.
As dlockers has said, get a level across the decking to make sure it falls away from the house.
