You've put the sauce on your bacon wrong... just saying.![]()
I've been umming and ahhing about how to migrate my storage to the Fractal.
As you can see above, I trashed the 3.5in drivebays, which left me with just the two optical bays.
I've always tried to use RAID to protect my data after spending the early part of my working life repairing servers and dealing with backups. So I was after a minimum of 3 drives.
I decided to get three tiny 2.5in 750GB Samsungs
To mount them I took a startech hot swap drivebay out of the old machine and after a bit of screwdriver work...
But... it really doesnt leave much room to work with inside...
I actually used the radiator to push the sata cables into the sockets! Just glad I found 4 right angle ones. I'll now need to go source some black ones...
Took a few attempts to get everything connected and working - had an issue with the caddies and one of the bays which meant I had to completely strip it down and rebuild it. But its all working now, and the PC is copying across the C: drive to an array across those three disks.
I've also been testing the SSD acceleration provided by the Z68 chipset - and as far as I can tell - it works really well. So I'll have 1.4TB of storage, with a 64GB SSD cache.
Once I've got some black cables instead of the ones I found, I'll tidy them up.
Ach! Nooo. Devils food.Have to agree, should have been brown![]()
Very nice build.
I was thinking of two caddies per drive bay with a spacer between. So a similar physical layout to the startech thing above, but hidden behind the blanking plate.
I wasnt thinking of screwing them into place, with the weight of those two radiators in there, that rig isnt going to be moved around a lot. I guess it depends on the thickness of the material as to whether there is room enough to fit sidewalls to it - basically replicating a CDrom drive size and shape. Heh, its just ideas anyway.
A couple of 40mm fans in there should provide enough airflow, although I may need to get a vented drivebay cover rather than the solid ones supplied.
I'll measure up the holes in the 5.25in bays anyhow and do a similar pic as above.
Hi sky ripper...jus a thught,you could mount the stand of the front side Rad on the side with the fans so that you have the rad sitting on the xact front of the case.....n have space..for mounting the lower harddrive mount next to it...it will involve abit of modding but i thnk will be worth it.
They're not SSDs. While I'd love to have a 1.4TB SSD array, am sure my wallet could not take that kind of abuse.
