You can fit a 120.2 as stock on the existing fan grilles and holes.
You *could* fit a 120.3 with one of two options - drill out some new holes to fit in line with the 3rd fan grille, or cut out the third fan grille to match the other two.
This really bad paint picture should show what I mean. (bodged on my laptop at work)
If you go the easy route, and mod some additional 120mm fan holes (purple circles), then you are going to have 15-30mm (thats a guess) of room, which may or may not leave enough room for heatsinks and RAM. If you have a thick radiator then I would say there will not be room. My RAM sits behind my radiator and its not got huge heatsinks or anything.
The more difficult route would be to expand the third 120mm fan grille (red box) which should give you enough room. You'll still have to pop the top and front off your case and measure it up to be sure - don't forget rads have bits on each end which stick out past the fan grills. This gives you 65mm or more between your motherboard tray and the side of the radiator.
Pop the top off, grab a torch, and test fit a 120.3 (or a cardboard cutout) for sure.
hey,,,,
thanx very much for the info....m planning on using the magic cool 120.3 slim rads....n 3 gentle typhoons...m hoping they will fit..without me needing to modify the case...
