I wish I could take credit for it but it's the default position offered by Phanteks in this case. It will make the tube from res to pump quite interesting, I wish I could mount the pump elsewhere but there isn't really a better spot.Love the pump behind the motherboard tray, great idea.
Thanks! I think you're right, especially after I got this done(sneak peek):Imho your cables look fantastic mate, really like the colour scheme. Again, only mho but I think you got the colour balance just right. The grey background makes the colours pop much more...
Really looking forward to this one when complete.
Nice, how many lights did you get? Any umbrellas etc?On a tiny sidenote, I got a hold of some studio lighting so my images should be better from now on(if I can just learn to use them properly as well).![]()
Yeah the monsta radiators are absolutely huge. Like a small radiator for a car, just crazy.Wow, these colours work really well together nice one, and those monster radiatorsReally looking forward to this one when complete.
Just trying my hand at acrylic now also, totally agree with your humbling comment, but getting those few right it a great feeling![]()
I just got the basic Elinchrom set, mainly cause I know nothing about lighting and for basic "product photography" it should be fine.Nice, how many lights did you get? Any umbrellas etc?
I recently made a little studio set up at home, and it makes a world of difference.
Thanks!Great progress made, looking very good in situ and cables will defo add more colour into the build. Good luck with final bends!
Nice! I cheaped out and just got 3x 175W daylight bulbs and some flash-through umbrellas.I just got the basic Elinchrom set, mainly cause I know nothing about lighting and for basic "product photography" it should be fine.
It's two lights with softboxes and a wireless transmitter. Here's a link to a product page: Elinchrom D-Lite RX-One
With some practice I think you can do some great work with just these two. Products, models, you name it. For an amateur they are more than enough imho.
I'm slightly surprised though that the SLI bridge doesn't use a coloured LED but a piece of coloured plastic
The project is looking good, you've done a great job with the bends as they all appear to go into the fittings flush with no angled entries.I'm slightly surprised though that the SLI bridge doesn't use a coloured LED but a piece of coloured plastic
Also what Monsoon Rotary fitting size did you use as it fits flush with the Primochill revolver fitting? I have had a look but can't find the size.
Great work and I look forward to seeing more updates![]()
Can you cut the plexiglass along the edges from the inside, removing the piece visible from the outside?
I'd guess the aluminium is glued, so doubtful you'd be successful removing it. Otherwise you could try to rip it off and vinyl wrap it afterwards.
It's unfortunate the original Nvidia SLI bridges are not sold in Europe..
Quickest leak test in the world of water cooling?
Started filling the res a bit and checked to see if everything was okay. It was not. The bottom of the res leaked like crazy.
So I removed it, checked the O-rings reassembled it and did a leak test on just the res. Seems fine now.
I apparantly didn't mount the golden end cap properly when I switched end caps.
So I reinstall it start filling again and .... I forgot about having someplace for the air to exit which basically ended up with me getting a face full of coolant(don't ask).
Fixed that issue and continued filling until the res was almost full. Started the pump... And I've mixed up inlet and outlet![]()
So now I can't use my drain port to empty the res and I have to empty it so I can redo the pipes for the pump after I've changed how I mounted it.
I can just remove the pipe from res to pump but I suspect it will get really messy, but it seems it's the only solution.
Lesson learned at least, double and triple check everything again after you've double and triple checked the first time.![]()
Yeah better to be honest about your mistakes so someone else might not have to do the same ones.Although I am not up to going full water yet, I am impressed with this build....and also with your build log Ohjay.
Nice to see someone admit to being human....and owning up to errors along the way.
I think there are many of us who learn far more about the pitfalls one can fall into, and how to avoid them, when you hear all about others hiccups.![]()
)Yeah seeing all that water going out of the res was not a fun experience. Thankfully I had nothing under power and most of it just ran through the fans and the rad and out of the case. But it still wasn't fun.Erghhhh. Have the same res and know your pain! Mine was slightly worse as it did not leak but rather gave out in one go when the res was filled to about 60%, wow I nearly cried as it went all over my PSU :/
I double and triple check now on this res to make sure I can't pull it off, even with a little bit of force applied.
All part of the learning curve I guess![]()
It's unfortunate and I'd love to say that you'll never make these mistakes again but it's easy to forget when you're wrapped up building your system. I'm certainly no stranger to receiving a face full of coolant due to forgeting about air in the systemQuickest leak test in the world of water cooling?
