Project: Virgin Enthusiast Build
Nice honest thread :) I remember when I built my first PC and ordered everything online. It was exciting. Now it's more...fun but always seems rushed in my hectic life to build the damn things. :) Enjoy matey.
didn't know ssd's could be that fast is it from krypton
SSDs can now saturate (including the overheads) the SATA 2 interface. this is running on the onboard SATA 3 interface on the gigabyte mobo.
SSDs are only going to get faster and faster, so get used to seeing numbers like that!
Putting the block(s) on the 480(s)...
Check out the amount of gunk nvidia uses!!!
And cleaned...
With all the EK pads on and sime artic silver spread on the GPU (using the "condom" method as some like to call it!)
the GPU didnt seem that flat and the EK block has a rough finish to it, so I would not worry about getting it too thin. Although that was two very thin lines spread out, so not a huge amount on there.
This shows the GPU reinforcer plate. I have heard stories of this shorting out the GPU. as you can see, with the washer in place, reinforcer plate screwed in and area kept clean of silver paste, there is a couple of millimeters clearance, so should be no problem.
Some shots of the EK standoffs. EK recommend putting a little bit of thermal paste on them to keep them in place. I think this is a good idea myself as they are little fiddly wee things that moved about a bit when placing the card on the block. However, try and do it a little cleaner than I did!!!
Card put on block to check all is sat well;
The followings hows that one of the standoffs was fouling the card. there was infact no hole in the card at the point EK had a tapped hole, so bit of an error there or the Inno3D isnt the default PCB, which seems odd.
with it removed:
card sits nice now, although it looks a bit off I think thats an optical illusion as it looked completely flat with no bending at all in real life.
And another couple of tapped holes that EK put in, but no holes on PCB for them!!!
seemed to still make a solid contact with the thermal pads, so hopefully will be ok:
And teh reference pic frmo EK's instructions, clearly showing where the two holes on the PCB should be.
noticed i missed some thermal pads, so good job i had another one to do!!!
was good oppurtunity to take the block off and check how the thermal pads and paste had contacted. I can report that the contacts were spot on, so good work EK :)
This last one shows that there is plenty of clearance between the fittings on the block and the Gigabyte hybrid silent heatpipe.
im a bit worried about the water pipe slot connector between the cards. it moves about a bit. although there is a double rubber ring inside, it doesnt feel that secure. anyone else confirm if this is ok?
got some more little bits and bobs on order such as dust filters and the like.
Also found a local water jet cutting company, so off to get a quote tomorrow for some side panel cutting :D
