Had a bit of an odd one today. Realised that my prep on the roof was nowhere near adequate for paint (did a few test patches and was not impressed with the results) so that's now tomorrows task, get it really flat and smooth. Despite using spirits, sanding and scraping, there's still pits, bits of glue and roughness in patches.
(The primer was just to cover some bare metal, I later tried some satin on it)
I then proceeded to get into an argument with my roller and paint tray, for some reason the paint's acting up and not going on well and it also doesn't seem to be covering much ground. Consequently I got bored and just hit the spraycans - it's still wet in most of these shots but gets the idea across:
(Maybe.....)
Really impressed with the mileage I'm getting out of the Halfords satin sprays, so I'm kinda inclined to just do the whole damned thing in it now and save my paint for internal panels and detail work, or bulking areas out. You get a nice smooth finish as well, provided you prep the surface to a suitable standard. Maybe it's just that I'm more comptent with spray than I am brush, I just can't repeat the result I had on the bonnet at the moment.
Tomorrow I'm going to have to prep every panel well, mask everything up and get it all good and clean so I can just get a rattle on with the cans. I also did some 'crossover' tests today on previously sprayed satin, to see how easily you can blend between the panels so I'll find out the results of that tomorrow.
I still need to take the windscreen out.
I also still need to take the rear bumper and hitch off.
Must prep everything really well......it's all in the prep! It's boring and unrewarding but I just
have to get it done so I can move on with any effectiveness. Just bumbled around too much today.
Tell you what though - it's
black. Turn off the lights and the satin parts just.....evaporate into nothingness!
Good view through the Webasto too:
