- 26 Aug 2004
I've got a spare circuit all built up here. I will heatshrink and then do the test after that and send it to you. I will get it to the post office Friday afternoon so you should get it Saturday with a bit of luck.
I'm not sure what has gone wrong with that one. This is the first one I've had a problem with out in the field, as it were, but it seems to be not receiving PWM properly. As I said it was tested but admittedly that was done before I fitted the heatshrink so maybe the extra pressure of the heatshrink has opened a connection somewhere.
I will do the testing before after heatshrink in future to be sure.![]()
OK many thanks.
Shall I return the cable back to you?
The switches were expensive (comparatively so) and a pain to solder up neatly.
