quick question ? !
im not sure if doing the thing right in cpu-z it shows its using only 1.589 or something so maybe i gave to much volts ?
Nah the voltage in Windows will almost always be a fair bit less than what you set in the BIOS.
That's still far too high tbh.
Again I would drop it to 1.6v in BIOS and try to get stable there before considering adding any more voltage.
3.6ghz stable is really hard to get with a B3 without getting dangerous temps. Mine needs 1.525v in BIOS (1.47v in Windows) to be stable at 3.5ghz and keep load temps below 70c.
Yeah see if you can run Prime95 for 8 hours at 1.55v at 3510mhz.
But keep a close eye on your temps.
witch option to run on prime95 Blend(tests some of everything, lots of ram tested) ?
Edit: running on 1.5875 not sure if stable was not booting at any voltage below
, but why i need so much voltage ? i seen gibo is running q6600 on air well its g0 on 1.45v
Try upping your FSB Term. and Northbridge voltages by 0.1v (you might need to go to 1.4v for the NB voltage).
Keep lowering your FSB til you can get it stable. That will give you a platform to work from.
pretty ****** off and fed up killing me here lol
3420mhz, 380x9, 1.55 v , still prime 95 crashes after like 1 or 2 seconds maybe im doing something wrong :confused:
