quick question ? !
on 350x9, 1.4v, restarted tried prime failed again then while it was restarting window showed overcloking failed...
solution = ( opening my window ready to trow the pc from 2nd flour :) )
Why did you drop to 1.4v?
There's no point in changing multiple options at the same time if you're trying to find a stable overclock.
Either try to find which voltage is needed to get 350x9 stable, or try to find which overclock is stable at a particular voltage eg- 1.4v or 1.5v or 1.55v.
well look at 380x9 1.55v everything boots fine but i think at any frequancy and voltage etc prime95 crashes me
edit: maybe i should try ortos ?instead prime95
Orthos will only stress 2 cores.
I would try to get stable at 350x9 before attempting anything else. You shouldn't need much more than 1.5v in BIOS for that.
at least its working 350x9 at 1.5 v prime95 running but dam i want to push it to 3.5 at least
edit: running 10 min ... just crashed after 10 min pc just went on shut down what now ? any other good ideas guru of overcloking Cob :)
