QUICK QUESTION!
Just connect 1.
Anyway, turn your PC on, if the CPU fan doesn't spin, turn it off ASAP, if it does spin, you should be safe :)
Nothing happend thats because I don't have the power button or anything like that connected to motherboard because I don't know where each one goes!
So stressed out right now.
Refer to the motherboard manual for that. It will help you the most, look for f panel connectors in the contents page.
Okay, so have connected JFP1 AND JFP2 theres a spare one but thats not mentioned in the motherboards manual so not sure whats thats used for.
It says to then plug in; HDD LED & RESET SW.
But I don't seem to be able to find these wires.
They will be coming from the case. Look at where the power and reset buttons are on your case, then look in side of the case and try and find them wires, reset will be RESET SW e.g
They will probably be labeled as well.
you should be able to push them straight onto the motherboard, this is the quickest way
get the power switch cable ussaly 2 pin or 3 pin, from the pwoer button on the case, plug it in to where youre motherboard maual says it should, and plug the pc in at the mains, connect it to a monitor and hit the press the power switch, hopefully it will turn on.
front pannel connections cant really damage the board or get damaged to easily, so just work you're way from there
There will be a thing on your motherboard where all of the f panel connectors, such as RESET_SW and HDD LED etc plug in to.
Altough looking back in the manual it appears a power LED connections goes into JFP2 so does that mean i need to un-wrap the second and slot that into place?
Turn it on and see lol
Edit: you just made a new post. Just turn it on and see if you're happy with what you see and if anything is wrong.
Just plug them all in.
I doubt you've broken it.
It'll look like this:
