dale1uk said:have a look at these.
http://www.thermaltake.com/dcfans/led/thunderblade120.htm
they push loads of air, 78cfm, at a low noise, 21db and can be had for about £10
anyone got one to report on if they are really are any good??
pabloB said:Ok i'll have a look for those. The Stats I got were from a competitor (shame OCUK don't stock more fans) so don't know if they are good or not
This 120mm one I did buy is certainly very good.
Dirk said:I wish a hardware review site would do the definitive benchtest on a wide range of fans to answer the questions once and for all. Wonder how many fans are louser/less efficient than the quoted figures?
Raikiri said:They are crap, this http://www.thermaltake.com/dcfans/ComboCool/a2329/a2329.htm is good though
MeddlE said:Just ordered a set of those for my Stacker (3 x 120mm & 1 x 80mm), will let you know what I think.
Mundu said:Just been reading on the SPCR forums and apparently the silent CAT fans aren't all they're made ouyt to be.
farooqm said:Another vote for the Akasa Amber Ultra Quiet 120mm. They really are quiet.
Personally I'm going to be getting a Nexus 120mm seems to be a very reliable and quiet fan.
To me this makes no logical sense as 38mm fans should be quieter than a 25mm of the same RPM due to the depth
Cyber-Mav said:can vouch here for the akasa amber fans for being good.
