I'm 27 years old, been in what most would consider a great industry and I've made a decent amount of money along the way.
I have about 5 and a half years of living expenses saved up.
I am desperately unhappy in my job. The folks I work with are extremely political and throw you under the bus whenever possible. The work is really unfulfilling and the hours are 12+ hours a day.
I really have had enough, I am currently set on quitting at the end of the day. I said this before but didn't go through with it but am a lot more set on it now. I just wanted to get some other people's opinions to make sure I'm not making a dumb decision.
Searching for a new job while maintaining this one is very challenging. Can rarely get away during the day.
How do you work on post mortems, don't you need lots of training?
So doubtful! Yes I'm a trainee
So what you actually do? Is it years if medical. Or more technician, photographer or something else. If it's even anything like TV shows.
It's interesting to read how many others did the same as I did. I thought I was the only one stupid enough to actually do it but it seems notIt also looks to have worked out for most people.
You know the bromide: “a winner never quits, and a quitter never wins.”
To which Freakonomics Radio says … Are you sure? Sometimes quitting is strategic, and sometimes it can be your best possible plan.
To help us understand quitting, we look at a couple of key economic concepts in this episode: sunk cost and opportunity cost. Sunk cost is about the past – it’s the time or money or sweat equity you’ve put into a job or relationship or a project, and which makes quitting hard. Opportunity cost is about the future. It means that for every hour or dollar you spend on one thing, you’re giving up the opportunity to spend that hour or dollar on something else – something that might make your life better. If only you weren’t so worried about the sunk cost. If only you could …. quit.
Any update, get the new job?
