Baldyman said:Good luck kdd. Will you be trying any patches/inhalers/gum etc, or just will power?
=walls= said:patches are great - helps with the craving whilst you work out what to do with your hands... then once you've got that sorted, you can work on the nicotine addiction![]()
gjrc said:i am about to go on a drug called champix...
check it out!
check it out!
kdd said:I have been a smoker for 8 years exactly and had what I hope will be my last ever smoke about an hour ago. Wish me luck please!!!! Anyone else stopping smoking after the public ban etc etc?
Wardie said:I'm sure I read once that the physical addiction actually only lasts a couple of days, and the rest is mental?
