Definately starting to see the advantage of water at these vcores and speeds. I reckon if I had watercooling and could get 1.5v through this chip, its a defo 3.6ghz around the 70 mark. The Amanda is definately holding her ground. Definately worth the £35 I paid for it inc on the Member Market!
Kingy1968 said:FLASH BUGGERS!!!! lmao
Why Oh why cant i get low temps on air....
I feel like smashing it up
Cob said:I know water makes a difference, but I didn't expect to see a 25c difference in stock idle temps between the water and some of the air cooled chips.
Some chips must just naturally be a lot warmer than others.
)sarge78 said:Hi,
I've a question regarding the thermal specification for the QX6700. On Intels web site, here, its says the maximum thermal spec is 65°C.
This seems quite high, the QX6800 is only 55!, so does it mean that this particular chip can/is suppose to run hot?
Thanks.
ps,
Kingy1968 - I'll swap your quad for my E2160 (before you smash it up)
Cob said:They also say the max vcore should be 1.375v![]()
Kingy1968 said:HAAA HAAAAAA!!! Maybe someone could help me here...
As I posted above my temps idle on my q6600 are around the 51-55oC mark using TAT or CORETEMP program...
However if i reboot my machine and then go into the bios and then go to the Hardware Monitor my cpu and motherboard temperature show in there as 34oC and 34oC.
Can anyone shed any light on what might be the problem?
I mean is the bios hardware monitor more accurate than the TAT and Coretemp program?
Thanks
Kingy1968 said:I tried the chip on me m8s pc and the temps were still the same, so i put it down to either a faulty chip as one of the tech guys suggested at OCUK or the H/S and fan wernt good enough..
I decided to take the plunge and rip off the heatsink and give it a good lapping on some 600 grit wet and dry and then 1500 grit to finish it off..
I managed to get it as shiny as i could and then I cleaned it all with nail varnish remover to remove any residue.
Reapplied artic silver to the chip and a slight coating to the H/S and put it on the board..
Ive now managed to get the temps idle to about 47-48oc maybe a little hotter depending on room temp, but at least ive managed to shave about 7 or 8oC so at the moment im quite happy until i get a new heatsink so i can overclock this beastie...
Thanks Guys for the help
