Radeon HD 6990 leaked slides
5 Dec 2010
Source:http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=auto&tl=en&u=http%3A%2F%2Fwww.donanimhaber.com%2Fekran-karti%2Fhaberleri%2FAMDden-dunyanin-en-hizli-ekran-karti-Tum-detaylariyla-Radeon-HD-6990.htm
I can tell from seeing a lot of shopedewoops in my time that this is defiantly real :/
Tbh its right around the corner and i will beleive it when i see it, two 6970s are 50% faster then a single gtx 580 were in gods name are they getting a ni extra 20% from? from my understanding two seperate cards running 1 core will run about the same as 1 card using two of the same core's.
Maybe AMD are surprising us and using 28nm??
Maybe they will be releasing something more powerful than the 580 to compete with it and using two of those on the 6990.
The card usage is around 450w so that would suggest two 70's
Alex Hull @ Vortez said:
I can now confirm that the card will utilise two PCIe 8-pin connectors. This means the power requirements have gone up, and the most interesting question is why? We saw EVGA show off their Nvidia dual-GPU card at CES 2011 in January, widely assumed to be a version of the upcoming GTX 590, which used the same power configuration. It may be an attempt by AMD to match or even beat the performance of the GTX 590, which makes things very interesting indeed.
http://www.vortez.net/news_story/amd_radeon_hd_6990_antilles_to_launch_march_8th.html
according to tPU @ 2560x1600
6950CF is 40% faster than gtx 580 on Avg
since 6990OC is 67% ,stock one will be around 60% i guess,
which doesn't look right
I've published this and summarised my thoughts on some of the more interesting observations.
Two versions of the card, Normal and 'OC', differing in clockspeed from 830MHz to 880MHz respectively. A switch-able configuration using the Dual-BIOS on the card, to give higher core speed and voltage.
The 'OC' version sports a massive 450W TDP, confirming the extra power requirements we hinted at yesterday.
67% faster than a GTX 580.
Almost perfect scaling for CrossfireX in certain configurations.
What do you guys think - does that cover it or are there any other subtle nuggets of info of note that we're missing?
Should make a good fight with the GTX 590. I believe nVidia were waiting for AMD to make the first move, so this is it and they seem to have gone all-out, moreso than we expected. I think nVidia can probably match (at least) the performance, but can they compete on price too? Doubtful, but should be interesting. It highlights the other point though, the GTX 590 is going to be expensive, now the HD 6990 looks very pricey too - they're never going to be remotely mainstream, and if we're pushing 450W you're going to need a serious rig to do these justice anyway. They probably won't even reach the market penetration of the GTX 295 or HD 5990 in my opinion, and will be reserved for super-high end.
TBH i don't really see the point of dual GPU card these days, I mean it would be better to crossfire/SLI two cards IMO, if you can afford these cards you surely must have a high spec mobo that can support SLI/crossfire.
I don't think it's fake. If it is, they've gone to some lengths to produce a full presentation. All the facts make sense with what we know so far - I've even seem glimpses of the actual card over the net, and the increased TDP is reflected in the 2x8-pin config, rather than the 6/8 pin we saw when AMD's Matt Skynner showed off the card in January.
